Time Before: 0.00749 seconds
Time After: 0.00992 seconds
Time Taken: 0.00243 seconds
Time Before: 0.01002 seconds
Time After: 0.01122 seconds
Time Before: 0.01191 seconds
Time After: 0.01210 seconds
Time Before: 0.01298 seconds
Time After: 0.01541 seconds
Time Before: 0.01217 seconds
Time After: 0.01972 seconds
Time Taken: 0.00755 seconds
Time Before: 0.02415 seconds
Time After: 0.02456 seconds
Time Before: 0.02603 seconds
Time After: 0.02727 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02347 seconds
Time After: 0.02749 seconds
Time Taken: 0.00402 seconds
Memory After: 2,261.836 KB
Time Before: 0.04640 seconds
Time After: 0.04661 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05151 seconds
Time After: 0.05280 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.05497407913208
Time Before: 0.05826 seconds
Time After: 0.05845 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06135 seconds
Time After: 0.06296 seconds
Time Taken: 0.00161 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789139619, location = '/forums/private.php?do=newpm&explain=1&u=59895', badlocation = 1
Time Before: 0.07991 seconds
Time After: 0.08025 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.07873010635376 seconds with 9 queries, spending 0.0091016292572021 doing MySQL queries and 0.069628477096558 doing PHP things.
