Time Before: 0.00140 seconds
Time After: 0.00193 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00201 seconds
Time After: 0.00245 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00267 seconds
Time After: 0.00278 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00339 seconds
Time After: 0.00553 seconds
Time Taken: 0.00215 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00283 seconds
Time After: 0.00899 seconds
Time Taken: 0.00616 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.01102 seconds
Time After: 0.01156 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.01444 seconds
Time After: 0.01564 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.01037 seconds
Time After: 0.01590 seconds
Time Taken: 0.00553 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.02273 seconds
Time After: 0.02287 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.02533 seconds
Time After: 0.02658 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
End call of global.php: 0.029388904571533
Time Before: 0.03069 seconds
Time After: 0.03083 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.03409 seconds
Time After: 0.03557 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
SET lastactivity = 1776602916, location = '/forums/private.php?do=newpm&explain=1&u=60145'
Time Before: 0.05016 seconds
Time After: 0.05048 seconds
Memory Before: 4,922.117 KB
Memory After: 4,922.320 KB
Memory Used: 0.203 KB
Page generated in 0.049237012863159 seconds with 9 queries, spending 0.0077764987945557 doing MySQL queries and 0.041460514068604 doing PHP things.
