Time Before: 0.00972 seconds
Time After: 0.01354 seconds
Time Taken: 0.00381 seconds
Time Before: 0.01367 seconds
Time After: 0.01416 seconds
Time Before: 0.01441 seconds
Time After: 0.01459 seconds
Time Before: 0.01551 seconds
Time After: 0.01817 seconds
Time Taken: 0.00266 seconds
Time Before: 0.01467 seconds
Time After: 0.02244 seconds
Time Taken: 0.00777 seconds
Time Before: 0.02690 seconds
Time After: 0.02727 seconds
Time Before: 0.02985 seconds
Time After: 0.03133 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02622 seconds
Time After: 0.03155 seconds
Time Taken: 0.00532 seconds
Memory After: 2,261.836 KB
Time Before: 0.04778 seconds
Time After: 0.04801 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05821 seconds
Time After: 0.05972 seconds
Time Taken: 0.00151 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.06528 seconds
Time After: 0.06545 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06787 seconds
Time After: 0.06935 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788916234, location = '/forums/private.php?do=newpm&explain=1&u=60258' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.08873 seconds
Time After: 0.08908 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
