Time Before: 0.00141 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00242 seconds
Time Before: 0.00265 seconds
Time After: 0.00278 seconds
Time Before: 0.00342 seconds
Time After: 0.00624 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00282 seconds
Time After: 0.00974 seconds
Time Taken: 0.00692 seconds
Time Before: 0.01163 seconds
Time After: 0.01198 seconds
Time Before: 0.01438 seconds
Time After: 0.01572 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01104 seconds
Time After: 0.01590 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02113 seconds
Time After: 0.02132 seconds
Time Before: 0.02362 seconds
Time After: 0.02526 seconds
Time Taken: 0.00165 seconds
End call of global.php: 0.026882171630859
Time Before: 0.02817 seconds
Time After: 0.02836 seconds
Time Before: 0.03035 seconds
Time After: 0.03180 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=60290', badlocation = 1
Time Before: 0.04424 seconds
Time After: 0.04452 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.043305158615112 seconds with 9 queries, spending 0.0088810920715332 doing MySQL queries and 0.034424066543579 doing PHP things.
