Time Before: 0.03665 seconds
Time After: 0.04652 seconds
Time Taken: 0.00987 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.04665 seconds
Time After: 0.04709 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.04737 seconds
Time After: 0.04754 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.04827 seconds
Time After: 0.05059 seconds
Time Taken: 0.00231 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.04761 seconds
Time After: 0.05489 seconds
Time Taken: 0.00728 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.06437 seconds
Time After: 0.06505 seconds
Time Taken: 0.00068 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.06745 seconds
Time After: 0.06866 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.06354 seconds
Time After: 0.06888 seconds
Time Taken: 0.00533 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.12924 seconds
Time After: 0.12937 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.21095 seconds
Time After: 0.21222 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.21441006660461
Time Before: 0.25734 seconds
Time After: 0.25750 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.26308 seconds
Time After: 0.26458 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=60311', badlocation = 1
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.29467 seconds
Time After: 0.29492 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
Page generated in 0.29356813430786 seconds with 9 queries, spending 0.0081086158752441 doing MySQL queries and 0.28545951843262 doing PHP things.
