Time Before: 0.01498 seconds
Time After: 0.02034 seconds
Time Taken: 0.00536 seconds
Time Before: 0.02045 seconds
Time After: 0.02087 seconds
Time Before: 0.02110 seconds
Time After: 0.02124 seconds
Time Before: 0.02198 seconds
Time After: 0.02486 seconds
Time Taken: 0.00289 seconds
Time Before: 0.02129 seconds
Time After: 0.02889 seconds
Time Taken: 0.00760 seconds
Time Before: 0.03586 seconds
Time After: 0.03632 seconds
Time Before: 0.03945 seconds
Time After: 0.04067 seconds
Time Before: 0.03517 seconds
Time After: 0.04090 seconds
Time Taken: 0.00573 seconds
Time Before: 0.06795 seconds
Time After: 0.06808 seconds
Time Before: 0.07869 seconds
Time After: 0.07990 seconds
Time Before: 0.08597 seconds
Time After: 0.08611 seconds
Time Before: 0.08871 seconds
Time After: 0.09012 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=60350' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.10877 seconds
Time After: 0.10900 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
