Time Before: 0.00154 seconds
Time After: 0.00199 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00205 seconds
Time After: 0.00248 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00272 seconds
Time After: 0.00284 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00374 seconds
Time After: 0.00607 seconds
Time Taken: 0.00233 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00291 seconds
Time After: 0.01032 seconds
Time Taken: 0.00741 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01211 seconds
Time After: 0.01244 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01500 seconds
Time After: 0.01620 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01153 seconds
Time After: 0.01638 seconds
Time Taken: 0.00485 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.02171 seconds
Time After: 0.02182 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.02356 seconds
Time After: 0.02477 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.026427984237671
Time Before: 0.02775 seconds
Time After: 0.02793 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.03083 seconds
Time After: 0.03225 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=60545'
Time Before: 0.04471 seconds
Time After: 0.04503 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.043832063674927 seconds with 9 queries, spending 0.0076441764831543 doing MySQL queries and 0.036187887191772 doing PHP things.
