Time Before: 0.02229 seconds
Time After: 0.02964 seconds
Time Taken: 0.00735 seconds
Time Before: 0.02975 seconds
Time After: 0.03031 seconds
Time Taken: 0.00056 seconds
Time Before: 0.03067 seconds
Time After: 0.03089 seconds
Time Before: 0.03167 seconds
Time After: 0.03405 seconds
Time Taken: 0.00238 seconds
Time Before: 0.03094 seconds
Time After: 0.03804 seconds
Time Taken: 0.00710 seconds
Time Before: 0.04614 seconds
Time After: 0.04653 seconds
Time Before: 0.04927 seconds
Time After: 0.05051 seconds
Time Before: 0.04551 seconds
Time After: 0.05075 seconds
Time Taken: 0.00524 seconds
Time Before: 0.07971 seconds
Time After: 0.07986 seconds
Time Before: 0.10010 seconds
Time After: 0.10137 seconds
Time Before: 0.11326 seconds
Time After: 0.11349 seconds
Time Before: 0.11631 seconds
Time After: 0.11775 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=60551' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.13811 seconds
Time After: 0.13835 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
