Time Before: 0.02492 seconds
Time After: 0.03312 seconds
Time Taken: 0.00820 seconds
Time Before: 0.03321 seconds
Time After: 0.03430 seconds
Time Taken: 0.00109 seconds
Time Before: 0.03462 seconds
Time After: 0.03476 seconds
Time Before: 0.03567 seconds
Time After: 0.03942 seconds
Time Taken: 0.00375 seconds
Time Before: 0.03486 seconds
Time After: 0.04347 seconds
Time Taken: 0.00861 seconds
Time Before: 0.05138 seconds
Time After: 0.05180 seconds
Time Before: 0.05334 seconds
Time After: 0.05454 seconds
Time Before: 0.05067 seconds
Time After: 0.05475 seconds
Time Taken: 0.00408 seconds
Time Before: 0.09204 seconds
Time After: 0.09218 seconds
Time Before: 0.11644 seconds
Time After: 0.11772 seconds
End call of global.php: 0.12047982215881
Time Before: 0.12768 seconds
Time After: 0.12782 seconds
Time Before: 0.13055 seconds
Time After: 0.13197 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=60568', badlocation = 1
Time Before: 0.14876 seconds
Time After: 0.14903 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.14774799346924 seconds with 9 queries, spending 0.009850025177002 doing MySQL queries and 0.13789796829224 doing PHP things.
