Time Before: 0.00169 seconds
Time After: 0.00231 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00238 seconds
Time After: 0.00284 seconds
Time Before: 0.00306 seconds
Time After: 0.00317 seconds
Time Before: 0.00389 seconds
Time After: 0.00708 seconds
Time Taken: 0.00319 seconds
Time Before: 0.00322 seconds
Time After: 0.01214 seconds
Time Taken: 0.00892 seconds
Time Before: 0.01395 seconds
Time After: 0.01432 seconds
Time Before: 0.01706 seconds
Time After: 0.01826 seconds
Time Before: 0.01336 seconds
Time After: 0.01855 seconds
Time Taken: 0.00519 seconds
Time Before: 0.02521 seconds
Time After: 0.02537 seconds
Time Before: 0.02772 seconds
Time After: 0.02911 seconds
Time Taken: 0.00139 seconds
End call of global.php: 0.031384944915771
Time Before: 0.03277 seconds
Time After: 0.03292 seconds
Time Before: 0.03545 seconds
Time After: 0.03694 seconds
SET lastactivity = 1776998759, location = '/forums/private.php?do=newpm&explain=1&u=60695'
WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.05080 seconds
Time After: 0.05108 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.049570083618164 seconds with 9 queries, spending 0.0087924003601074 doing MySQL queries and 0.040777683258057 doing PHP things.
