Time Before: 0.00138 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00222 seconds
Time Before: 0.00241 seconds
Time After: 0.00258 seconds
Time Before: 0.00332 seconds
Time After: 0.00570 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00262 seconds
Time After: 0.00910 seconds
Time Taken: 0.00647 seconds
Time Before: 0.01099 seconds
Time After: 0.01139 seconds
Time Before: 0.01397 seconds
Time After: 0.01530 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01025 seconds
Time After: 0.01554 seconds
Time Taken: 0.00529 seconds
Time Before: 0.02245 seconds
Time After: 0.02260 seconds
Time Before: 0.02489 seconds
Time After: 0.02633 seconds
End call of global.php: 0.029062032699585
Time Before: 0.03057 seconds
Time After: 0.03073 seconds
Time Before: 0.03275 seconds
Time After: 0.03419 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=6096', badlocation = 1
Time Before: 0.04869 seconds
Time After: 0.04893 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
Page generated in 0.047760963439941 seconds with 9 queries, spending 0.0080440044403076 doing MySQL queries and 0.039716958999634 doing PHP things.
