Time Before: 0.00935 seconds
Time After: 0.01489 seconds
Time Taken: 0.00554 seconds
Time Before: 0.01497 seconds
Time After: 0.01539 seconds
Time Before: 0.01573 seconds
Time After: 0.01586 seconds
Time Before: 0.01680 seconds
Time After: 0.01903 seconds
Time Taken: 0.00223 seconds
Time Before: 0.01595 seconds
Time After: 0.02445 seconds
Time Taken: 0.00850 seconds
Time Before: 0.03083 seconds
Time After: 0.03121 seconds
Time Before: 0.03400 seconds
Time After: 0.03522 seconds
Time Before: 0.03006 seconds
Time After: 0.03554 seconds
Time Taken: 0.00548 seconds
Time Before: 0.05926 seconds
Time After: 0.05942 seconds
Time Before: 0.06881 seconds
Time After: 0.07003 seconds
End call of global.php: 0.072457075119019
Time Before: 0.07824 seconds
Time After: 0.07840 seconds
Time Before: 0.08115 seconds
Time After: 0.08260 seconds
SET lastactivity = 1784719737, location = '/forums/private.php?do=newpm&explain=1&u=61097'
Time Before: 0.10078 seconds
Time After: 0.10106 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.099601984024048 seconds with 9 queries, spending 0.0076749324798584 doing MySQL queries and 0.091927051544189 doing PHP things.
