Time Before: 0.00137 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00243 seconds
Time Before: 0.00269 seconds
Time After: 0.00284 seconds
Time Before: 0.00352 seconds
Time After: 0.00598 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00289 seconds
Time After: 0.01131 seconds
Time Taken: 0.00842 seconds
Time Before: 0.01329 seconds
Time After: 0.01376 seconds
Time Before: 0.01620 seconds
Time After: 0.01740 seconds
Time Before: 0.01267 seconds
Time After: 0.01765 seconds
Time Taken: 0.00498 seconds
Time Before: 0.02407 seconds
Time After: 0.02424 seconds
Time Before: 0.02649 seconds
Time After: 0.02775 seconds
Time Before: 0.03153 seconds
Time After: 0.03174 seconds
Time Before: 0.03447 seconds
Time After: 0.03603 seconds
Time Taken: 0.00156 seconds
UPDATE session SET lastactivity = 1785385199, location = '/forums/private.php?do=newpm&explain=1&u=61171' WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.05042 seconds
Time After: 0.05074 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
