Time Before: 0.02676 seconds
Time After: 0.03482 seconds
Time Taken: 0.00806 seconds
Time Before: 0.03491 seconds
Time After: 0.03530 seconds
Time Before: 0.03555 seconds
Time After: 0.03571 seconds
Time Before: 0.03648 seconds
Time After: 0.03890 seconds
Time Taken: 0.00242 seconds
Time Before: 0.03576 seconds
Time After: 0.04292 seconds
Time Taken: 0.00716 seconds
Time Before: 0.05032 seconds
Time After: 0.05070 seconds
Time Before: 0.05214 seconds
Time After: 0.05334 seconds
Time Before: 0.04973 seconds
Time After: 0.05353 seconds
Time Taken: 0.00381 seconds
Time Before: 0.10092 seconds
Time After: 0.10105 seconds
Time Before: 0.11991 seconds
Time After: 0.12115 seconds
End call of global.php: 0.12317609786987
Time Before: 0.12969 seconds
Time After: 0.12984 seconds
Time Before: 0.13267 seconds
Time After: 0.13416 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=61182'
Time Before: 0.15253 seconds
Time After: 0.15283 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.15149903297424 seconds with 9 queries, spending 0.0078387260437012 doing MySQL queries and 0.14366030693054 doing PHP things.
