Time Before: 0.00191 seconds
Time After: 0.00248 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00258 seconds
Time After: 0.00317 seconds
Time Before: 0.00339 seconds
Time After: 0.00352 seconds
Time Before: 0.00421 seconds
Time After: 0.00683 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00357 seconds
Time After: 0.01025 seconds
Time Taken: 0.00668 seconds
Time Before: 0.01243 seconds
Time After: 0.01290 seconds
Time Before: 0.01534 seconds
Time After: 0.01663 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01176 seconds
Time After: 0.01681 seconds
Time Taken: 0.00505 seconds
Memory After: 2,261.836 KB
Time Before: 0.02199 seconds
Time After: 0.02220 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.69088 seconds
Time After: 0.69596 seconds
Time Taken: 0.00507 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.69835305213928
Time Before: 0.70180 seconds
Time After: 0.70231 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.70485 seconds
Time After: 0.70636 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788932259, location = '/forums/private.php?do=newpm&explain=1&u=61187', badlocation = 1
Time Before: 0.72454 seconds
Time After: 0.72474 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.7235689163208 seconds with 9 queries, spending 0.012600183486938 doing MySQL queries and 0.71096873283386 doing PHP things.
