Time Before: 0.02419 seconds
Time After: 0.03127 seconds
Time Taken: 0.00708 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03137 seconds
Time After: 0.03254 seconds
Time Taken: 0.00117 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03281 seconds
Time After: 0.03294 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03367 seconds
Time After: 0.03620 seconds
Time Taken: 0.00253 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03301 seconds
Time After: 0.04031 seconds
Time Taken: 0.00730 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05083 seconds
Time After: 0.05126 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05374 seconds
Time After: 0.05489 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.05012 seconds
Time After: 0.05510 seconds
Time Taken: 0.00498 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.08974 seconds
Time After: 0.08989 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.28699 seconds
Time After: 0.28825 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.29031682014465
Time Before: 0.32111 seconds
Time After: 0.32130 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.32735 seconds
Time After: 0.32880 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=61238'
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.35253 seconds
Time After: 0.35277 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
Page generated in 0.35147881507874 seconds with 9 queries, spending 0.0087060928344727 doing MySQL queries and 0.34277272224426 doing PHP things.
