Time Before: 0.00269 seconds
Time After: 0.00391 seconds
Time Before: 0.00398 seconds
Time After: 0.00452 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00474 seconds
Time After: 0.00491 seconds
Time Before: 0.00555 seconds
Time After: 0.00762 seconds
Time Taken: 0.00208 seconds
Time Before: 0.00496 seconds
Time After: 0.01324 seconds
Time Taken: 0.00828 seconds
Time Before: 0.01637 seconds
Time After: 0.01682 seconds
Time Before: 0.01922 seconds
Time After: 0.02045 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01572 seconds
Time After: 0.02062 seconds
Time Taken: 0.00490 seconds
Memory After: 2,261.719 KB
Time Before: 0.02758 seconds
Time After: 0.02779 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.03220 seconds
Time After: 0.03351 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.03881 seconds
Time After: 0.03919 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.04263 seconds
Time After: 0.04415 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=6137' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.06261 seconds
Time After: 0.06288 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.469 KB
Memory Used: 0.250 KB
