Time Before: 0.01033 seconds
Time After: 0.01286 seconds
Time Taken: 0.00252 seconds
Time Before: 0.01296 seconds
Time After: 0.01335 seconds
Time Before: 0.01359 seconds
Time After: 0.01373 seconds
Time Before: 0.01462 seconds
Time After: 0.01679 seconds
Time Taken: 0.00217 seconds
Time Before: 0.01381 seconds
Time After: 0.02103 seconds
Time Taken: 0.00723 seconds
Time Before: 0.02583 seconds
Time After: 0.02624 seconds
Time Before: 0.02900 seconds
Time After: 0.03025 seconds
Time Before: 0.02503 seconds
Time After: 0.03050 seconds
Time Taken: 0.00548 seconds
Time Before: 0.05021 seconds
Time After: 0.05035 seconds
Time Before: 0.05649 seconds
Time After: 0.05777 seconds
End call of global.php: 0.060851812362671
Time Before: 0.06441 seconds
Time After: 0.06457 seconds
Time Before: 0.06791 seconds
Time After: 0.06960 seconds
Time Taken: 0.00170 seconds
SET lastactivity = 1768556455, location = '/forums/private.php?do=newpm&explain=1&u=61427'
WHERE sessionhash = '698b7cee4307118c13af5f4d00fa7d61'
Time Before: 0.08780 seconds
Time After: 0.08815 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
Page generated in 0.086386919021606 seconds with 9 queries, spending 0.0079810619354248 doing MySQL queries and 0.078405857086182 doing PHP things.
