Time Before: 0.00165 seconds
Time After: 0.00222 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00228 seconds
Time After: 0.00270 seconds
Time Before: 0.00291 seconds
Time After: 0.00305 seconds
Time Before: 0.00370 seconds
Time After: 0.00618 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00310 seconds
Time After: 0.00962 seconds
Time Taken: 0.00652 seconds
Time Before: 0.01139 seconds
Time After: 0.01180 seconds
Time Before: 0.01414 seconds
Time After: 0.01551 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01084 seconds
Time After: 0.01568 seconds
Time Taken: 0.00484 seconds
Time Before: 0.02138 seconds
Time After: 0.02152 seconds
Time Before: 0.02561 seconds
Time After: 0.02684 seconds
Time Before: 0.03026 seconds
Time After: 0.03044 seconds
Time Before: 0.03337 seconds
Time After: 0.03483 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=61583' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04953 seconds
Time After: 0.04996 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
