Time Before: 0.01846 seconds
Time After: 0.02413 seconds
Time Taken: 0.00568 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02424 seconds
Time After: 0.02468 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02496 seconds
Time After: 0.02509 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02585 seconds
Time After: 0.02836 seconds
Time Taken: 0.00251 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02517 seconds
Time After: 0.03374 seconds
Time Taken: 0.00857 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04060 seconds
Time After: 0.04096 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04348 seconds
Time After: 0.04526 seconds
Time Taken: 0.00178 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04000 seconds
Time After: 0.04547 seconds
Time Taken: 0.00547 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.07380 seconds
Time After: 0.07402 seconds
Memory Before: 3,655.680 KB
Memory After: 3,656.195 KB
Time Before: 0.11190 seconds
Time After: 0.11319 seconds
Memory Before: 4,133.273 KB
Memory After: 4,133.867 KB
End call of global.php: 0.11521100997925
Time Before: 0.13482 seconds
Time After: 0.13500 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.13960 seconds
Time After: 0.14107 seconds
Memory Before: 5,481.203 KB
Memory After: 5,610.805 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=61649', badlocation = 1
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.15816 seconds
Time After: 0.15841 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.969 KB
Page generated in 0.15722990036011 seconds with 9 queries, spending 0.0086503028869629 doing MySQL queries and 0.14857959747314 doing PHP things.
