Time Before: 0.00793 seconds
Time After: 0.01244 seconds
Time Taken: 0.00451 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.01254 seconds
Time After: 0.01299 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.01324 seconds
Time After: 0.01341 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.01419 seconds
Time After: 0.01680 seconds
Time Taken: 0.00260 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.01346 seconds
Time After: 0.02214 seconds
Time Taken: 0.00868 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.02933 seconds
Time After: 0.02971 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.03231 seconds
Time After: 0.03351 seconds
Memory Before: 2,148.203 KB
Memory After: 2,148.063 KB
Time Before: 0.02848 seconds
Time After: 0.03373 seconds
Time Taken: 0.00525 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.086 KB
Time Before: 0.04685 seconds
Time After: 0.04701 seconds
Memory Before: 2,814.633 KB
Memory After: 2,815.148 KB
Time Before: 0.05823 seconds
Time After: 0.05972 seconds
Memory Before: 2,902.938 KB
Memory After: 2,903.531 KB
End call of global.php: 0.062053918838501
Time Before: 0.06566 seconds
Time After: 0.06584 seconds
Memory Before: 3,539.703 KB
Memory After: 3,540.133 KB
Time Before: 0.06859 seconds
Time After: 0.07007 seconds
Memory Before: 3,821.234 KB
Memory After: 3,822.922 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=61745'
Time Before: 0.08730 seconds
Time After: 0.08773 seconds
Memory Before: 4,294.844 KB
Memory After: 4,295.086 KB
Page generated in 0.086248874664307 seconds with 9 queries, spending 0.0085444450378418 doing MySQL queries and 0.077704429626465 doing PHP things.
