Time Before: 0.02779 seconds
Time After: 0.03764 seconds
Time Taken: 0.00985 seconds
Time Before: 0.03778 seconds
Time After: 0.04040 seconds
Time Taken: 0.00262 seconds
Time Before: 0.04073 seconds
Time After: 0.04092 seconds
Time Before: 0.04181 seconds
Time After: 0.04443 seconds
Time Before: 0.04099 seconds
Time After: 0.04855 seconds
Time Taken: 0.00756 seconds
Time Before: 0.05630 seconds
Time After: 0.05694 seconds
Time Taken: 0.00064 seconds
Time Before: 0.06036 seconds
Time After: 0.06163 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05550 seconds
Time After: 0.06185 seconds
Time Taken: 0.00635 seconds
Memory After: 2,261.836 KB
Time Before: 0.11196 seconds
Time After: 0.11215 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.13163 seconds
Time After: 0.13285 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.14299 seconds
Time After: 0.14317 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.14562 seconds
Time After: 0.14705 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789037545, location = '/forums/private.php?do=newpm&explain=1&u=61781', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.16371 seconds
Time After: 0.16414 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
