Time Before: 0.00164 seconds
Time After: 0.00222 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00232 seconds
Time After: 0.00291 seconds
Time Before: 0.00319 seconds
Time After: 0.00337 seconds
Time Before: 0.00433 seconds
Time After: 0.00688 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00344 seconds
Time After: 0.01172 seconds
Time Taken: 0.00828 seconds
Time Before: 0.01356 seconds
Time After: 0.01394 seconds
Time Before: 0.01658 seconds
Time After: 0.01775 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01298 seconds
Time After: 0.01792 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02308 seconds
Time After: 0.02322 seconds
Time Before: 0.02561 seconds
Time After: 0.02689 seconds
End call of global.php: 0.029839038848877
Time Before: 0.03121 seconds
Time After: 0.03136 seconds
Time Before: 0.03453 seconds
Time After: 0.03607 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1785288048, location = '/forums/private.php?do=newpm&explain=1&u=61785'
Time Before: 0.05102 seconds
Time After: 0.05130 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.04963207244873 seconds with 9 queries, spending 0.0082392692565918 doing MySQL queries and 0.041392803192139 doing PHP things.
