Time Before: 0.00927 seconds
Time After: 0.01214 seconds
Time Taken: 0.00287 seconds
Time Before: 0.01224 seconds
Time After: 0.01262 seconds
Time Before: 0.01286 seconds
Time After: 0.01302 seconds
Time Before: 0.01392 seconds
Time After: 0.01636 seconds
Time Taken: 0.00244 seconds
Time Before: 0.01310 seconds
Time After: 0.02060 seconds
Time Taken: 0.00750 seconds
Time Before: 0.02652 seconds
Time After: 0.02672 seconds
Time Before: 0.03006 seconds
Time After: 0.03128 seconds
Time Before: 0.02561 seconds
Time After: 0.03152 seconds
Time Taken: 0.00591 seconds
Time Before: 0.05340 seconds
Time After: 0.05354 seconds
Time Before: 0.06482 seconds
Time After: 0.06610 seconds
Time Before: 0.07313 seconds
Time After: 0.07331 seconds
Time Before: 0.07682 seconds
Time After: 0.07829 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=61881', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.09359 seconds
Time After: 0.09397 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
