Time Before: 0.00196 seconds
Time After: 0.00278 seconds
Time Taken: 0.00082 seconds
Time Before: 0.00286 seconds
Time After: 0.00330 seconds
Time Before: 0.00358 seconds
Time After: 0.00372 seconds
Time Before: 0.00460 seconds
Time After: 0.00871 seconds
Time Taken: 0.00411 seconds
Time Before: 0.00380 seconds
Time After: 0.01225 seconds
Time Taken: 0.00846 seconds
Time Before: 0.01431 seconds
Time After: 0.01470 seconds
Time Before: 0.01788 seconds
Time After: 0.01989 seconds
Time Taken: 0.00202 seconds
Time Before: 0.01357 seconds
Time After: 0.02020 seconds
Time Taken: 0.00663 seconds
Time Before: 0.02811 seconds
Time After: 0.02847 seconds
Time Before: 0.03219 seconds
Time After: 0.03359 seconds
Time Taken: 0.00139 seconds
Time Before: 0.03808 seconds
Time After: 0.03822 seconds
Time Before: 0.04065 seconds
Time After: 0.04284 seconds
Time Taken: 0.00219 seconds
UPDATE session SET lastactivity = 1788897366, location = '/forums/private.php?do=newpm&explain=1&u=61917' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.06300 seconds
Time After: 0.06336 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
