Time Before: 0.00145 seconds
Time After: 0.00198 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00205 seconds
Time After: 0.00263 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00292 seconds
Time After: 0.00310 seconds
Time Before: 0.00386 seconds
Time After: 0.00665 seconds
Time Taken: 0.00279 seconds
Time Before: 0.00318 seconds
Time After: 0.01022 seconds
Time Taken: 0.00704 seconds
Time Before: 0.01209 seconds
Time After: 0.01257 seconds
Time Before: 0.01501 seconds
Time After: 0.01634 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01153 seconds
Time After: 0.01651 seconds
Time Taken: 0.00498 seconds
Time Before: 0.02169 seconds
Time After: 0.02192 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"14.19,\";s:9:\"lastcheck\";i:1789070244;}', 1)Time Before: 0.02801 seconds
Time After: 0.02879 seconds
Time Taken: 0.00078 seconds
Memory Before: 3,439.641 KB
Memory After: 3,439.891 KB
Memory Used: 0.250 KB
Time Before: 0.03133 seconds
Time After: 0.03271 seconds
Time Taken: 0.00139 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
Time Before: 0.03654 seconds
Time After: 0.03673 seconds
Memory Before: 4,164.313 KB
Memory After: 4,164.742 KB
Time Before: 0.03894 seconds
Time After: 0.04039 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1789070244, location = '/forums/private.php?do=newpm&explain=1&u=61952' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05393 seconds
Time After: 0.05416 seconds
Memory Before: 4,919.750 KB
Memory After: 4,919.977 KB
