Time Before: 0.00143 seconds
Time After: 0.00206 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00213 seconds
Time After: 0.00252 seconds
Time Before: 0.00272 seconds
Time After: 0.00285 seconds
Time Before: 0.00358 seconds
Time After: 0.00609 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00290 seconds
Time After: 0.00956 seconds
Time Taken: 0.00666 seconds
Time Before: 0.01147 seconds
Time After: 0.01166 seconds
Time Before: 0.01464 seconds
Time After: 0.01582 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01084 seconds
Time After: 0.01599 seconds
Time Taken: 0.00515 seconds
Time Before: 0.02098 seconds
Time After: 0.02113 seconds
Time Before: 0.02322 seconds
Time After: 0.02445 seconds
End call of global.php: 0.026938915252686
Time Before: 0.02840 seconds
Time After: 0.02855 seconds
Time Before: 0.03099 seconds
Time After: 0.03256 seconds
Time Taken: 0.00156 seconds
SET lastactivity = 1785288019, location = '/forums/private.php?do=newpm&explain=1&u=62056', badlocation = 1
Time Before: 0.05259 seconds
Time After: 0.05297 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.051143884658813 seconds with 9 queries, spending 0.0078706741333008 doing MySQL queries and 0.043273210525513 doing PHP things.
