Time Before: 0.02424 seconds
Time After: 0.03020 seconds
Time Taken: 0.00596 seconds
Time Before: 0.03030 seconds
Time After: 0.03071 seconds
Time Before: 0.03094 seconds
Time After: 0.03107 seconds
Time Before: 0.03190 seconds
Time After: 0.03410 seconds
Time Taken: 0.00220 seconds
Time Before: 0.03113 seconds
Time After: 0.03846 seconds
Time Taken: 0.00733 seconds
Time Before: 0.04597 seconds
Time After: 0.04641 seconds
Time Before: 0.04926 seconds
Time After: 0.05056 seconds
Time Before: 0.04500 seconds
Time After: 0.05083 seconds
Time Taken: 0.00583 seconds
Time Before: 0.08923 seconds
Time After: 0.08940 seconds
Time Before: 0.10811 seconds
Time After: 0.10942 seconds
Time Before: 0.11927 seconds
Time After: 0.11963 seconds
Time Before: 0.12232 seconds
Time After: 0.12377 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=62115', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.14417 seconds
Time After: 0.14448 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
