Time Before: 0.00133 seconds
Time After: 0.00191 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00199 seconds
Time After: 0.00248 seconds
Time Before: 0.00281 seconds
Time After: 0.00299 seconds
Time Before: 0.00391 seconds
Time After: 0.00676 seconds
Time Taken: 0.00285 seconds
Time Before: 0.00307 seconds
Time After: 0.01237 seconds
Time Taken: 0.00930 seconds
Time Before: 0.01453 seconds
Time After: 0.01492 seconds
Time Before: 0.01747 seconds
Time After: 0.01865 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01380 seconds
Time After: 0.01883 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02433 seconds
Time After: 0.02451 seconds
Time Before: 0.02639 seconds
Time After: 0.02760 seconds
End call of global.php: 0.029235124588013
Time Before: 0.03045 seconds
Time After: 0.03057 seconds
Time Before: 0.03255 seconds
Time After: 0.03403 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=62305', badlocation = 1
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.04765 seconds
Time After: 0.04796 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.046703100204468 seconds with 9 queries, spending 0.0083677768707275 doing MySQL queries and 0.03833532333374 doing PHP things.
