Time Before: 0.00217 seconds
Time After: 0.00288 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00298 seconds
Time After: 0.00341 seconds
Time Before: 0.00366 seconds
Time After: 0.00380 seconds
Time Before: 0.00462 seconds
Time After: 0.00698 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00388 seconds
Time After: 0.01242 seconds
Time Taken: 0.00854 seconds
Time Before: 0.01490 seconds
Time After: 0.01525 seconds
Time Before: 0.01765 seconds
Time After: 0.01886 seconds
Time Before: 0.01423 seconds
Time After: 0.01903 seconds
Time Taken: 0.00480 seconds
Time Before: 0.02568 seconds
Time After: 0.02584 seconds
Time Before: 0.02804 seconds
Time After: 0.02927 seconds
End call of global.php: 0.032060861587524
Time Before: 0.03348 seconds
Time After: 0.03364 seconds
Time Before: 0.03704 seconds
Time After: 0.03847 seconds
SET lastactivity = 1776791431, location = '/forums/private.php?do=newpm&explain=1&u=6236', badlocation = 1
Time Before: 0.05205 seconds
Time After: 0.05234 seconds
Memory Before: 4,911.445 KB
Memory After: 4,911.656 KB
Page generated in 0.051048040390015 seconds with 9 queries, spending 0.0077531337738037 doing MySQL queries and 0.043294906616211 doing PHP things.
