Time Before: 0.00144 seconds
Time After: 0.00200 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00207 seconds
Time After: 0.00247 seconds
Time Before: 0.00276 seconds
Time After: 0.00289 seconds
Time Before: 0.00378 seconds
Time After: 0.00634 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00297 seconds
Time After: 0.01001 seconds
Time Taken: 0.00704 seconds
Time Before: 0.01213 seconds
Time After: 0.01253 seconds
Time Before: 0.01583 seconds
Time After: 0.01709 seconds
Time Before: 0.01152 seconds
Time After: 0.01729 seconds
Time Taken: 0.00576 seconds
Time Before: 0.02249 seconds
Time After: 0.02263 seconds
Time Before: 0.02465 seconds
Time After: 0.02593 seconds
End call of global.php: 0.027804136276245
Time Before: 0.02930 seconds
Time After: 0.02944 seconds
Time Before: 0.03181 seconds
Time After: 0.03325 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=62408'
Time Before: 0.04838 seconds
Time After: 0.04867 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.047458171844482 seconds with 9 queries, spending 0.0080330371856689 doing MySQL queries and 0.039425134658813 doing PHP things.
