Time Before: 0.00145 seconds
Time After: 0.00224 seconds
Time Taken: 0.00079 seconds
Time Before: 0.00231 seconds
Time After: 0.00269 seconds
Time Before: 0.00287 seconds
Time After: 0.00299 seconds
Time Before: 0.00370 seconds
Time After: 0.00678 seconds
Time Taken: 0.00308 seconds
Time Before: 0.00304 seconds
Time After: 0.01016 seconds
Time Taken: 0.00712 seconds
Time Before: 0.01213 seconds
Time After: 0.01257 seconds
Time Before: 0.01546 seconds
Time After: 0.01665 seconds
Time Before: 0.01150 seconds
Time After: 0.01684 seconds
Time Taken: 0.00535 seconds
Time Before: 0.02224 seconds
Time After: 0.02249 seconds
Time Before: 0.02460 seconds
Time After: 0.02588 seconds
End call of global.php: 0.027637958526611
Time Before: 0.02901 seconds
Time After: 0.02913 seconds
Time Before: 0.03116 seconds
Time After: 0.03355 seconds
Time Taken: 0.00239 seconds
SET lastactivity = 1788873050, location = '/forums/private.php?do=newpm&explain=1&u=62584'
Time Before: 0.04592 seconds
Time After: 0.04630 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.044997930526733 seconds with 9 queries, spending 0.0096359252929688 doing MySQL queries and 0.035362005233765 doing PHP things.
