Time Before: 0.00137 seconds
Time After: 0.00192 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00199 seconds
Time After: 0.00254 seconds
Time Before: 0.00276 seconds
Time After: 0.00285 seconds
Time Taken: 0.00009 seconds
Time Before: 0.00344 seconds
Time After: 0.00565 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00290 seconds
Time After: 0.00902 seconds
Time Taken: 0.00612 seconds
Time Before: 0.01099 seconds
Time After: 0.01131 seconds
Time Before: 0.01258 seconds
Time After: 0.01377 seconds
Time Before: 0.01039 seconds
Time After: 0.01395 seconds
Time Taken: 0.00357 seconds
Time Before: 0.02054 seconds
Time After: 0.02071 seconds
Time Before: 0.02297 seconds
Time After: 0.02461 seconds
Time Taken: 0.00164 seconds
End call of global.php: 0.026303052902222
Time Before: 0.02750 seconds
Time After: 0.02764 seconds
Time Before: 0.03041 seconds
Time After: 0.03181 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1789115203, location = '/forums/private.php?do=newpm&explain=1&u=62593'
Time Before: 0.04576 seconds
Time After: 0.04613 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.044829130172729 seconds with 9 queries, spending 0.0080695152282715 doing MySQL queries and 0.036759614944458 doing PHP things.
