Time Before: 0.01247 seconds
Time After: 0.01624 seconds
Time Taken: 0.00377 seconds
Time Before: 0.01635 seconds
Time After: 0.01728 seconds
Time Taken: 0.00093 seconds
Time Before: 0.01753 seconds
Time After: 0.01767 seconds
Time Before: 0.01847 seconds
Time After: 0.02082 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01776 seconds
Time After: 0.02451 seconds
Time Taken: 0.00675 seconds
Time Before: 0.02815 seconds
Time After: 0.02855 seconds
Time Before: 0.03104 seconds
Time After: 0.03224 seconds
Time Before: 0.02752 seconds
Time After: 0.03245 seconds
Time Taken: 0.00492 seconds
Time Before: 0.05320 seconds
Time After: 0.05337 seconds
Time Before: 0.06153 seconds
Time After: 0.06278 seconds
Time Before: 0.07001 seconds
Time After: 0.07018 seconds
Time Before: 0.07362 seconds
Time After: 0.07520 seconds
Time Taken: 0.00158 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=62617', badlocation = 1 WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.09265 seconds
Time After: 0.09779 seconds
Time Taken: 0.00515 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
