Time Before: 0.00254 seconds
Time After: 0.00303 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00311 seconds
Time After: 0.00351 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00370 seconds
Time After: 0.00382 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00469 seconds
Time After: 0.00728 seconds
Time Taken: 0.00259 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00387 seconds
Time After: 0.01238 seconds
Time Taken: 0.00851 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01525 seconds
Time After: 0.01570 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01893 seconds
Time After: 0.02017 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.01371 seconds
Time After: 0.02039 seconds
Time Taken: 0.00667 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.02847 seconds
Time After: 0.02863 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.03764 seconds
Time After: 0.03884 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.04727 seconds
Time After: 0.04747 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.04989 seconds
Time After: 0.05137 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=62681', badlocation = 1 WHERE sessionhash = 'cf9a7d249f143a0ae3eb7b561aa7a27f'
Time Before: 0.06867 seconds
Time After: 0.06893 seconds
Memory Before: 5,998.492 KB
Memory After: 5,998.711 KB
