Time Before: 0.01118 seconds
Time After: 0.01537 seconds
Time Taken: 0.00420 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.01546 seconds
Time After: 0.01591 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.01627 seconds
Time After: 0.01643 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.01728 seconds
Time After: 0.02017 seconds
Time Taken: 0.00289 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.01649 seconds
Time After: 0.02426 seconds
Time Taken: 0.00777 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.03213 seconds
Time After: 0.03257 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.03519 seconds
Time After: 0.03649 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.03126 seconds
Time After: 0.03678 seconds
Time Taken: 0.00552 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.05432 seconds
Time After: 0.05444 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.06443 seconds
Time After: 0.06570 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.067608833312988
Time Before: 0.07278 seconds
Time After: 0.07292 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.07532 seconds
Time After: 0.07700 seconds
Time Taken: 0.00168 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=62745'
Time Before: 0.09532 seconds
Time After: 0.09902 seconds
Time Taken: 0.00370 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.094319820404053 seconds with 9 queries, spending 0.012139797210693 doing MySQL queries and 0.082180023193359 doing PHP things.
