Time Before: 0.01654 seconds
Time After: 0.02522 seconds
Time Taken: 0.00868 seconds
Time Before: 0.02534 seconds
Time After: 0.02654 seconds
Time Before: 0.02681 seconds
Time After: 0.02697 seconds
Time Before: 0.02784 seconds
Time After: 0.03070 seconds
Time Taken: 0.00286 seconds
Time Before: 0.02705 seconds
Time After: 0.03573 seconds
Time Before: 0.04562 seconds
Time After: 0.04599 seconds
Time Before: 0.04852 seconds
Time After: 0.04975 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04488 seconds
Time After: 0.04994 seconds
Time Taken: 0.00506 seconds
Memory After: 2,261.836 KB
Time Before: 0.08337 seconds
Time After: 0.08353 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.09985 seconds
Time After: 0.10108 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.11213 seconds
Time After: 0.11231 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.11470 seconds
Time After: 0.11616 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789043327, location = '/forums/private.php?do=newpm&explain=1&u=62821', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.13505 seconds
Time After: 0.13540 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
