Time Before: 0.02419 seconds
Time After: 0.03134 seconds
Time Taken: 0.00715 seconds
Time Before: 0.03142 seconds
Time After: 0.03186 seconds
Time Before: 0.03215 seconds
Time After: 0.03229 seconds
Time Before: 0.03306 seconds
Time After: 0.03547 seconds
Time Taken: 0.00241 seconds
Time Before: 0.03236 seconds
Time After: 0.03974 seconds
Time Taken: 0.00738 seconds
Time Before: 0.04863 seconds
Time After: 0.04907 seconds
Time Before: 0.05199 seconds
Time After: 0.05326 seconds
Time Before: 0.04799 seconds
Time After: 0.05352 seconds
Time Taken: 0.00553 seconds
Time Before: 0.08531 seconds
Time After: 0.08548 seconds
Time Before: 0.09628 seconds
Time After: 0.09756 seconds
End call of global.php: 0.10043692588806
Time Before: 0.10724 seconds
Time After: 0.10744 seconds
Time Before: 0.11000 seconds
Time After: 0.11146 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=62822'
Time Before: 0.12888 seconds
Time After: 0.12917 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.12779998779297 seconds with 9 queries, spending 0.0081181526184082 doing MySQL queries and 0.11968183517456 doing PHP things.
