Time Before: 0.01390 seconds
Time After: 0.02103 seconds
Time Taken: 0.00713 seconds
Time Before: 0.02113 seconds
Time After: 0.02237 seconds
Time Before: 0.02261 seconds
Time After: 0.02273 seconds
Time Before: 0.02342 seconds
Time After: 0.02531 seconds
Time Taken: 0.00189 seconds
Time Before: 0.02278 seconds
Time After: 0.03041 seconds
Time Taken: 0.00763 seconds
Time Before: 0.03690 seconds
Time After: 0.03734 seconds
Time Before: 0.04046 seconds
Time After: 0.04193 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03622 seconds
Time After: 0.04217 seconds
Time Taken: 0.00595 seconds
Memory After: 2,261.836 KB
Time Before: 0.05569 seconds
Time After: 0.05582 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.06864 seconds
Time After: 0.06993 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.072398900985718
Time Before: 0.07995 seconds
Time After: 0.08010 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.08284 seconds
Time After: 0.08430 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789015451, location = '/forums/private.php?do=newpm&explain=1&u=62859'
Time Before: 0.09925 seconds
Time After: 0.09952 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.098286867141724 seconds with 9 queries, spending 0.0084531307220459 doing MySQL queries and 0.089833736419678 doing PHP things.
