Time Before: 0.01942 seconds
Time After: 0.02385 seconds
Time Taken: 0.00443 seconds
Time Before: 0.02392 seconds
Time After: 0.02436 seconds
Time Before: 0.02459 seconds
Time After: 0.02472 seconds
Time Before: 0.02543 seconds
Time After: 0.02771 seconds
Time Taken: 0.00228 seconds
Time Before: 0.02477 seconds
Time After: 0.03180 seconds
Time Taken: 0.00703 seconds
Time Before: 0.03858 seconds
Time After: 0.03880 seconds
Time Before: 0.04226 seconds
Time After: 0.04361 seconds
Time Taken: 0.00136 seconds
Time Before: 0.03766 seconds
Time After: 0.04385 seconds
Time Taken: 0.00620 seconds
Time Before: 0.08185 seconds
Time After: 0.08197 seconds
Time Before: 0.40784 seconds
Time After: 0.40920 seconds
End call of global.php: 0.41227793693542
Time Before: 0.42197 seconds
Time After: 0.42212 seconds
Time Before: 0.42489 seconds
Time After: 0.42638 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=63070', badlocation = 1
Time Before: 0.44371 seconds
Time After: 0.44397 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.44260907173157 seconds with 9 queries, spending 0.0077943801879883 doing MySQL queries and 0.43481469154358 doing PHP things.
