Time Before: 0.00178 seconds
Time After: 0.00225 seconds
Time Before: 0.00232 seconds
Time After: 0.00288 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00318 seconds
Time After: 0.00347 seconds
Time Before: 0.00439 seconds
Time After: 0.00753 seconds
Time Taken: 0.00315 seconds
Time Before: 0.00352 seconds
Time After: 0.01197 seconds
Time Taken: 0.00846 seconds
Time Before: 0.01425 seconds
Time After: 0.01469 seconds
Time Before: 0.01750 seconds
Time After: 0.01890 seconds
Time Taken: 0.00139 seconds
Time Before: 0.01345 seconds
Time After: 0.01918 seconds
Time Taken: 0.00573 seconds
Time Before: 0.02630 seconds
Time After: 0.02652 seconds
Time Before: 0.02911 seconds
Time After: 0.03036 seconds
End call of global.php: 0.032934188842773
Time Before: 0.03429 seconds
Time After: 0.03448 seconds
Time Before: 0.03735 seconds
Time After: 0.03885 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=63095'
Time Before: 0.05304 seconds
Time After: 0.05333 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.052089214324951 seconds with 9 queries, spending 0.0092792510986328 doing MySQL queries and 0.042809963226318 doing PHP things.
