Time Before: 0.00814 seconds
Time After: 0.01076 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01085 seconds
Time After: 0.01124 seconds
Time Before: 0.01148 seconds
Time After: 0.01161 seconds
Time Before: 0.01251 seconds
Time After: 0.01473 seconds
Time Taken: 0.00222 seconds
Time Before: 0.01169 seconds
Time After: 0.01912 seconds
Time Taken: 0.00743 seconds
Time Before: 0.02375 seconds
Time After: 0.02413 seconds
Time Before: 0.02669 seconds
Time After: 0.02793 seconds
Time Before: 0.02304 seconds
Time After: 0.02818 seconds
Time Taken: 0.00514 seconds
Time Before: 0.04246 seconds
Time After: 0.04262 seconds
Time Before: 0.04950 seconds
Time After: 0.05072 seconds
Time Before: 0.05735 seconds
Time After: 0.05751 seconds
Time Before: 0.06024 seconds
Time After: 0.06166 seconds
UPDATE session SET lastactivity = 1776748769, location = '/forums/private.php?do=newpm&explain=1&u=63176' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.08057 seconds
Time After: 0.08087 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
