Time Before: 0.02395 seconds
Time After: 0.03200 seconds
Time Taken: 0.00805 seconds
Time Before: 0.03210 seconds
Time After: 0.03249 seconds
Time Before: 0.03296 seconds
Time After: 0.03308 seconds
Time Before: 0.03398 seconds
Time After: 0.03625 seconds
Time Taken: 0.00227 seconds
Time Before: 0.03314 seconds
Time After: 0.04051 seconds
Time Taken: 0.00737 seconds
Time Before: 0.04969 seconds
Time After: 0.05008 seconds
Time Before: 0.05275 seconds
Time After: 0.05402 seconds
Time Before: 0.04880 seconds
Time After: 0.05428 seconds
Time Taken: 0.00548 seconds
Time Before: 0.09626 seconds
Time After: 0.09640 seconds
Time Before: 0.11241 seconds
Time After: 0.11402 seconds
Time Taken: 0.00161 seconds
Time Before: 0.12782 seconds
Time After: 0.12798 seconds
Time Before: 0.13072 seconds
Time After: 0.13221 seconds
UPDATE session SET lastactivity = 1782988835, location = '/forums/private.php?do=newpm&explain=1&u=63211', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.15060 seconds
Time After: 0.15137 seconds
Time Taken: 0.00077 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
