Time Before: 0.01812 seconds
Time After: 0.02522 seconds
Time Taken: 0.00710 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02535 seconds
Time After: 0.02606 seconds
Time Taken: 0.00070 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02630 seconds
Time After: 0.02641 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02719 seconds
Time After: 0.02927 seconds
Time Taken: 0.00209 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02646 seconds
Time After: 0.03288 seconds
Time Taken: 0.00642 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04259 seconds
Time After: 0.04278 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04599 seconds
Time After: 0.04718 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.04165 seconds
Time After: 0.04745 seconds
Time Taken: 0.00580 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.07025 seconds
Time After: 0.07039 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.27671 seconds
Time After: 0.27807 seconds
Time Taken: 0.00136 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.30922 seconds
Time After: 0.30937 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.31403 seconds
Time After: 0.31554 seconds
Time Taken: 0.00151 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1772955664, location = '/forums/private.php?do=newpm&explain=1&u=63302', badlocation = 1 WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.34186 seconds
Time After: 0.34218 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
