Time Before: 0.00219 seconds
Time After: 0.00293 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00303 seconds
Time After: 0.00366 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00393 seconds
Time After: 0.00409 seconds
Time Before: 0.00477 seconds
Time After: 0.00754 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00414 seconds
Time After: 0.01102 seconds
Time Taken: 0.00688 seconds
Time Before: 0.01314 seconds
Time After: 0.01351 seconds
Time Before: 0.01601 seconds
Time After: 0.01729 seconds
Time Before: 0.01252 seconds
Time After: 0.01753 seconds
Time Taken: 0.00501 seconds
Time Before: 0.02320 seconds
Time After: 0.02331 seconds
Time Before: 0.02556 seconds
Time After: 0.02694 seconds
Time Taken: 0.00138 seconds
Time Before: 0.02999 seconds
Time After: 0.03016 seconds
Time Before: 0.03281 seconds
Time After: 0.03430 seconds
UPDATE session SET lastactivity = 1783254663, location = '/forums/private.php?do=newpm&explain=1&u=63343' WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.04820 seconds
Time After: 0.04848 seconds
Memory Before: 4,289.125 KB
Memory After: 4,289.352 KB
