Time Before: 0.01075 seconds
Time After: 0.01408 seconds
Time Taken: 0.00333 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.01418 seconds
Time After: 0.01474 seconds
Time Taken: 0.00055 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.01533 seconds
Time After: 0.01547 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.01636 seconds
Time After: 0.01910 seconds
Time Taken: 0.00273 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.01555 seconds
Time After: 0.02297 seconds
Time Taken: 0.00743 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.02750 seconds
Time After: 0.02793 seconds
Time Before: 0.02960 seconds
Time After: 0.03081 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02686 seconds
Time After: 0.03107 seconds
Time Taken: 0.00421 seconds
Memory After: 2,261.703 KB
Time Before: 0.05233 seconds
Time After: 0.05247 seconds
Memory Before: 2,815.273 KB
Memory After: 2,815.789 KB
Time Before: 0.06165 seconds
Time After: 0.06289 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.064899921417236
Time Before: 0.06875 seconds
Time After: 0.06890 seconds
Memory Before: 3,540.375 KB
Memory After: 3,540.805 KB
Time Before: 0.07117 seconds
Time After: 0.07258 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=63346'
Time Before: 0.08627 seconds
Time After: 0.08661 seconds
Memory Before: 4,295.484 KB
Memory After: 4,295.727 KB
Page generated in 0.085386991500854 seconds with 9 queries, spending 0.0083479881286621 doing MySQL queries and 0.077039003372192 doing PHP things.
