Time Before: 0.00179 seconds
Time After: 0.00242 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00249 seconds
Time After: 0.00290 seconds
Time Before: 0.00312 seconds
Time After: 0.00327 seconds
Time Before: 0.00412 seconds
Time After: 0.00639 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00332 seconds
Time After: 0.01040 seconds
Time Taken: 0.00708 seconds
Time Before: 0.01241 seconds
Time After: 0.01283 seconds
Time Before: 0.01655 seconds
Time After: 0.01781 seconds
Time Before: 0.01180 seconds
Time After: 0.01810 seconds
Time Taken: 0.00630 seconds
Time Before: 0.02525 seconds
Time After: 0.02542 seconds
Time Before: 0.02788 seconds
Time After: 0.02936 seconds
Time Before: 0.03470 seconds
Time After: 0.03489 seconds
Time Before: 0.03851 seconds
Time After: 0.04054 seconds
Time Taken: 0.00203 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=63393', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05598 seconds
Time After: 0.05628 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
