Time Before: 0.03119 seconds
Time After: 0.03936 seconds
Time Taken: 0.00817 seconds
Time Before: 0.03946 seconds
Time After: 0.03987 seconds
Time Before: 0.04011 seconds
Time After: 0.04023 seconds
Time Before: 0.04100 seconds
Time After: 0.04290 seconds
Time Taken: 0.00190 seconds
Time Before: 0.04029 seconds
Time After: 0.04696 seconds
Time Taken: 0.00667 seconds
Time Before: 0.05521 seconds
Time After: 0.05562 seconds
Time Before: 0.05847 seconds
Time After: 0.05973 seconds
Time Before: 0.05448 seconds
Time After: 0.05994 seconds
Time Taken: 0.00547 seconds
Time Before: 0.11572 seconds
Time After: 0.11583 seconds
Time Before: 0.13677 seconds
Time After: 0.13822 seconds
End call of global.php: 0.14118099212646
Time Before: 0.14852 seconds
Time After: 0.14867 seconds
Time Before: 0.15122 seconds
Time After: 0.15266 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=63573'
Time Before: 0.17274 seconds
Time After: 0.17302 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.17168593406677 seconds with 9 queries, spending 0.0075287818908691 doing MySQL queries and 0.1641571521759 doing PHP things.
