Time Before: 0.00147 seconds
Time After: 0.00258 seconds
Time Taken: 0.00111 seconds
Time Before: 0.00265 seconds
Time After: 0.00309 seconds
Time Before: 0.00329 seconds
Time After: 0.00347 seconds
Time Before: 0.00414 seconds
Time After: 0.00650 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00352 seconds
Time After: 0.01014 seconds
Time Taken: 0.00662 seconds
Time Before: 0.01211 seconds
Time After: 0.01255 seconds
Time Before: 0.01555 seconds
Time After: 0.01675 seconds
Time Before: 0.01152 seconds
Time After: 0.01699 seconds
Time Taken: 0.00548 seconds
Time Before: 0.02324 seconds
Time After: 0.02342 seconds
Time Before: 0.02522 seconds
Time After: 0.02648 seconds
End call of global.php: 0.028538942337036
Time Before: 0.03020 seconds
Time After: 0.03040 seconds
Time Before: 0.03349 seconds
Time After: 0.03494 seconds
SET lastactivity = 1788916639, location = '/forums/private.php?do=newpm&explain=1&u=63666'
Time Before: 0.04733 seconds
Time After: 0.04777 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.046416997909546 seconds with 9 queries, spending 0.0081470012664795 doing MySQL queries and 0.038269996643066 doing PHP things.
