Time Before: 0.02016 seconds
Time After: 0.02726 seconds
Time Taken: 0.00709 seconds
Time Before: 0.02739 seconds
Time After: 0.02829 seconds
Time Taken: 0.00090 seconds
Time Before: 0.02859 seconds
Time After: 0.02872 seconds
Time Before: 0.02955 seconds
Time After: 0.03167 seconds
Time Taken: 0.00212 seconds
Time Before: 0.02881 seconds
Time After: 0.03728 seconds
Time Taken: 0.00848 seconds
Time Before: 0.04647 seconds
Time After: 0.04686 seconds
Time Before: 0.04963 seconds
Time After: 0.05081 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04572 seconds
Time After: 0.05110 seconds
Time Taken: 0.00538 seconds
Memory After: 2,885.102 KB
Memory Used: 132.781 KB
Time Before: 0.10217 seconds
Time After: 0.10233 seconds
Memory Before: 3,438.195 KB
Memory After: 3,438.711 KB
Time Before: 0.11991 seconds
Time After: 0.12133 seconds
Memory Before: 3,525.867 KB
Memory After: 3,526.461 KB
End call of global.php: 0.12384605407715
Time Before: 0.13251 seconds
Time After: 0.13267 seconds
Memory Before: 4,163.750 KB
Memory After: 4,164.180 KB
Time Before: 0.13551 seconds
Time After: 0.13693 seconds
Memory Before: 4,445.289 KB
Memory After: 4,446.977 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=6384'
Time Before: 0.16157 seconds
Time After: 0.16211 seconds
Time Taken: 0.00054 seconds
Memory Before: 4,910.625 KB
Memory After: 4,910.875 KB
Memory Used: 0.250 KB
Page generated in 0.16027212142944 seconds with 9 queries, spending 0.0084187984466553 doing MySQL queries and 0.15185332298279 doing PHP things.
